Kelly avatar image
Kelly asked
KISS approach for 2 Quattro bypass - 4 AC Sources
Current panel has 4 AC sources (2 Shore/2 Gensets) for each section (120 I, 120 II, 240 I, 240 II) with a selector switch for each section (see image). This provides the ability to map any AC source to any of the 4 panel sections. I'm wiring in 2 2x120 3k Quattro's in Parallel. I'm looking for an appropriate solution to manually bypass the Quattro's (to use existing panel setup as-is). My thought was to interrupt the output of the 4xAC switches (output of selector switches for each section) to either toggle the inverter "in circuit" or out.
I assume someone with a larger boat has already done this. Did you use a rotary switch (12p? L1, N, L2 x4) or contactor?gogoac120240panelsmall.jpg
Quattro-II
Kelly avatar image
Kelly answered ·
Interesting no one has run across this! Was hoping it would have already been done. 4 AC sources, 2 Quattro's (in any configuration) for the most flexibility.
If not on this forum are there other areas to check?
Justin Cook avatar image
Justin Cook answered ·
I'd encourage you to discuss your proposed setup and wiring with an experienced and reputable marine systems electrician -preferably one well-versed in the Victron ecosystem- to determine the best path forward after a full review of not only your existing wiring but also the operation of the Quattro-IIs.
Part of my concern is that the Quattro-IIs each have 2 AC inputs, yes, but when paralleling them you don't then get 4 inputs, you still only have 2, because they're now operating as a single larger unit.
Also important to note that in parallel "stack" mode (for 6kVA output) they won't provide split-phase 120/240 when inverting, but if they're in parallel-split mode where inverted split-phase output would be possible (one unit providing 3kVA on L1, the second unit providing 3kVA on L2) then the L2 input of both units are disabled entirely which doesn't seem like your desired functionality.
I don't doubt that there's a way to achieve your desired functionality, but I do believe it's far beyond the purview of this public forum to determine that, thus my strong recommendation that you consult a reputable professional in the field to work out a plan.
Kelly avatar image
Kelly answered ·
Thanks and the reason I'm on this forum is that I have been working with two different Victron dealers and neither has a solution for this. What is throwing everyone is the use of any combo of 4 AC in's.
1) I do understand, that in Parallel mode, I'll only have 2 AC in's with my two Quattro's. Bummer given the potential functionality that could be enabled in software.
2) It isn't mandatory to have 240v as I can spin up on of the gensets for the occasional dryer run or main A/C.
3) There must be many applications with 3 or 4 AC in choices but I'm not seeing any schematics.
At this point I'm going with a transfer switch between each genset (to AC In #1) and a 4-combo selector switch (2 gensets and two Shore power)(to AC In#2). Not ideal!
***If the software could run two systems with unified control integration and data aggregation, my situation, and many others, could be solved. Two inverters, run through an integrated UI, but with separate power outputs to segregated panels.
Quattro II Product page
Quattro II Online Manual
Pre-RMA bench test instructions.
