dave23 avatar image
dave23 asked
Please check setup
Could you please check this basic setup, and comment if everything is ok or something is wrong or should be different.
1. Victron Energy MultiPlus-II 48V 15000VA/200-100 I 230V I Battery inverter
2. 3pcs Pylontech PV storage I US 5000 I low volt I 48 V I 4.8 kWh
3. Victron Energy SmartSolar MPPT RS 450/200-Tr 11.5 kW I solar charge controller
4. Jinko Solar solar module Tiger Neo I 440 Wp N-Type Mono I Full Black I palett (36pcs)
System would be for off grid surveillance, welding and future EV charging (with additional charger).
10 ip cameras x 10W = 100W x 24h = 2.4kW
1 router and NVR = 60W x 24h = 1.4kW
Multiplus II = 55W x 24h = 1.3kW
=5.1kW/day
Solar panel (cloudy day) = 36 x 30W = 1kW
Total loss = 4.1kW/day = 12.3kW/ 3 days
Battery x 3= 14.4kW
About 3 days autonomy if weather is not good.
offgrid
Duivert NL avatar image
Duivert NL answered ·
Hi, for system design its best to contact your local dealer, they can help you to calculate your setup
But what i see right now, battery is way to small, for on grid you need 20kW minimum, for off grid you need more
See
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
