The Epoch Battery 460Ah is only at 55% and has a voltage or 13.2. Using ignition charger.
Starts in Bulk charging mode and works well then after about 10-15 seconds goes into float mode.
Here are some screen shots of my settings and the float screen and the battery app values. It should not be going into float mode at all.
Screenshot_20240611_123445_Epoch.jpgScreenshot_20240611_123351.jpgScreenshot_20240611_123404.jpgScreenshot_20240611_123416.jpg
Can you add a screenshot of the trend from the output voltage and current made with VictronConnect?
It shows what the charger sees, maybe that explains what happens.
Niels
40 People are following this question.
