Hello
How does the data is store when the Raspberry does not have wifi or Ethernet
Here is my Setup
Victron Image = 2.33
Raspberry 3 B+
Window PC
Everything works when connected
Andre
Hello
Here is my Setup
Raspberry 3 B+
Window PC
Andre
The data is stored on the sdcard or on a usb drive if connected.
Small thing you can create a hotspot on your mobile phone and connect your rpi to your hotspot.
Activate your rpi at the vrm portal
Then data will be send to the vrm portal and you can see it thru the internet
Now every time your rpi finds your hotspot
Data is send & updated at the vrm portal
Ray
Hello
i have plug an USB drive to the Raspberry, i left the Raspberry running without any internet connection (wifi or ethernet)
no data was store on the USB drive duribng that period...
Any setting that has to be done to have the data store during a none Ethernet-wifi connection?
Andre
Hi @Fenix
The How to do that is mentioned on the below url
https://www.victronenergy.com/live/vrm_portal:getting_started
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
10 People are following this question.
