harttt62 avatar image
harttt62 asked
Is possible to fit a remote switch to Multiplus 12/800/35 as fitted under bed. Do Victron supply this product.
Do not want to leave inverter on when not using 240v
Multiplus-II
Yes, there are several ways.
Victron has a product range, depending on your needs - https://www.victronenergy.com/panel-systems-remote-monitoring
Specifically in your case, the digital multi control.
It is also possible to wire your own switch and run the "Safety Switch" Assistant - https://www.victronenergy.com/live/assistants:overview_of_available_assistants#safety_switch
Installing assistants requires some more detailed product knowledge.
If you have a Multi with the new enclosure there is a terminal at the bottom there you can connect a switch to turn the Multi ON and OFF.
https://www.victronenergy.com/inverters-chargers/multi-500-va
If you have an "older" MultiPlus Compact you have to open the front panel and on the lower end of the circuit board is the terminal for a remote switch.
No need off buying any other components or programming.
David avatar image
David answered ·
Another way is connect up the Bluetooth RJ45 Dongle and control the setting via your Mobile Phone (I noticed that the App gives you 4 different settings (On / Off / Inverter only / Charger Only) while the Device Mounted switch, the Remote Switch or the Digital Multi-Control only has the standard three (On / Off / Charger Only) :) )
Tom avatar image
Tom answered ·
I connected my Multiplus 24/3000 with a 3 wire duel position rocker switch located in another room. Total cost $7.
harttt62 answered ·
Thanks So Much Guys this was very helpful
