electritechnz avatar image
electritechnz asked
Low fuel alarm using a Cerbo GX and DSE 7420 MII via modbus
I have a system with an external fault light (beacon) that I would like to set up as an indicator for low fuel level on the generator. I will be connecting the generator with the Cerbo GX using a DSE 7420 MII controller via modbus. Is it possible to programme a relay on the cerbo GX to trigger in the event of low fuel with this arrangement?
I understand that the carbon GX has resistive tank level inputs but I am trying to avoid installing additional cabling if possible.
Cheers,
alarmexternal control
