The advanced tab is missing to prioritize energy sources. Multiplus ii, Color Control. Software is updated, Version 2780491. I can't figure it out.
What version of VE.Config do you have?
The MultiPlus needs to be at FW 506 or higher.
https://www.victronenergy.com/live/ve.bus:solar-and-wind-priority
491 is the FW of your MultiPlus, to see the version of VE.Config I think you have to go "help" (can't check it right now)
To update the FW of the MultiPlus:
OR
https://www.victronenergy.com/live/venus-os:remote_ve.bus_firmware_updates
OR
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
VE Config 3 shows on the help, just as in the pic. Checking for updates on the Color Control state up to date, also checked compatibility and it's good, (purchased everything this last year) and I'm not seeing the ability to update on the VRM, nothing below the devices on the device list like the video.
This is the current VE.config version:
To update the MultiPlus you need to read the links I posted above.
The easiest way is via VictronConnect (first link).
All settings are reset to default during the update!
47 People are following this question.
