libraryman3 avatar image
libraryman3 asked
D+ signal voltage
I’ve fitted a relay to bypass my std battery charging system,
I have just checked that it’s working and measured the voltage at the D+ cable.
I recorded 14.4 volts.
Is this D+ voltage to high, could it damage the Orion xs 50amp charger?
I note that the minimum start voltage is circa 4 volts.
Regards R
connection issue
