This is a bunch of components that I've already got except for the DC-DC charger.
Looking to rewire things to the following configuration.
Input welcome. I'm sure it can use some help...
Shunt should be closer to battery. I.e. Orion neg should be on the other side of the shunt.
Do you really want to push 80A through a 50A max charger?probably wants to be on the battery side of the Orion.
The 80 amp vs 50 amp is a good question... If I understand correctly, the 50 amp is for output, the amount of power available for charging can be higher. The DC-Dc charger shouldn't pull more than it can use.
Thoughts? Thanks for the comment!
43 People are following this question.
