grua avatar image
grua asked
Node-RED Control PV Inverter Limit doesn't work on Fronius SYMO
Tried to limit PV Inverter to e.g. 3000 W via:
PV Inverter Control
This node is for setting information into the PV inverter.
Power limit (W), dbus path: /Ac/PowerLimit, type float
But it doesn't work as expected. I thought the PV production would be limited to 3000W, but it isn't. What are possible reasons?:
Node-RED
@grua
Moved to modifications as it's a Node-RED question
markus-001 avatar image
markus-001 answered ·
check the Fronius settings, Dynamic power reduction might be set to
No limit or set to use percentage instead of watts
