tom-croon avatar image
tom-croon asked
Venus GX and Modbus TCP
Hi!
I have connected with the Venus GX and charging is working. I have troubles to discharge the battery.
The commands I'm using are:
Commands for charging:
Modbus adres
Value
38 (Charge)
0
39 (Feeding)
1
37 (Setpoint charge/Discharge)
1000
Feedback from Venus GX
Bulk
Commands for discharging:
Modbus adres
Value
38 (Charge)
1
39 (Feeding)
0
-1000
PassTrue
Charging is working by writing these values, but discharging isn't. Does anyone have any Idea why this isn't working? The values are written every 200ms.
Thank you in advance!
Modbus TCP
Ole Saether avatar image Ole Saether commented ·
What exactly are you trying to do?
I discharge my batteries by connecting loads to them, not by writing the Modbus.
Alistair Warburton avatar image
Alistair Warburton answered ·
I am saying this a great del just recently... I am NOT a Victron expert
However if you tell an inverter charger not to charge and it still has an AC input its only option would be to ignore, and not use the powre, or pass it directly to the load thus not using the battery.
I suspect pass through is just that, input to output with the battery idle.
You will probably find that it will do what you want if you set it up to do that in the fist place. My point is that yor commands are probably correct but your basic setup isnt, or at least isnt what you think it is.
To be honest I dont understand what you are trying to do but the responce dosnt look silly from a device that will probably be attempting to maintain batter SOC untilll you tell it not to or it cant because there is no AC input.
my guess is that the response uld be 'inverting' if you physically disconnected the input or told it to ignore it.
