kaarthik avatar image
kaarthik asked
multiplus inverter tripped when ac power cut happens.
good morning
i was connected 2.5kWh lithium battery with 3kVA multiplus inverter when ever there is a power cut the battery getting tripped and inverter shows low battery and entire system off.here i was attached the battery voltage details and ve bus warning shows that High DC Ripple is that a reason for shutdown.
ben avatar image
ben answered ·
Sounds like a BMS issue. What's your question?
Ah you were faster...
ben avatar image ben ♦ Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
Rare, but true! :)
Hi @kaarthik
You can see by the voltage / current graph, that your battery is not connected, this can be either a wiring issue / broken fuse, or your battery has a built in disonnect.
What brand / type of batteries are you using?
