ukgab avatar image
ukgab asked
MPPT 75/15 V1.14 PV+ terminal screw siezd
I'm attempting to upgrade my solar panels but the PV+ terminal screw won't move.
I've tried everything I know for 2 days now.
Any tips before I cancel tomorrows planned getaway ?
Or any ideas as to what happened, only that terminal & the very end of the cable affected, all other terminals on the controller and everything else in the 'electrics' cupboard is fine.
Thanks,
Gary.
MPPT Controllers
cardy01 avatar image
cardy01 answered ·
On mine - it can appear seized if I don't use a screwdriver bit which is a very good fit for the slot
ukgab avatar image
ukgab answered ·
Thanks, definitely the correct screwdriver, now it's on a bench with the board supported I have to be careful not to snap it off the board.
cardy01 avatar image cardy01 commented ·
I had exactly the same issue on Tuesday .... 2 minute task took 35 ... good luck
ukgab avatar image
ukgab answered ·
Day 2 now, I'm going to have to order a replacement, I'll see if I can find someone to solder a replacement terminal block in situ when home again.
It's been a great controller until now.
Duivert NL avatar image Duivert NL commented ·
Normally you could heat it up, but since its plastic cant do that
you could freeze it with freezespray
