i want to set up a VLAN on my Raspberry PI 3B in Venos OS. How can I install the VLAN driver?
Greetings from Stefan Harbich
Since my hardware only has one LAN port and I want to manage it from a different network, the operating system must support VLAN tagging. Can I build Venos OS myself? Is there a git where I can add packages myself using make menuconfig? Greetings from Stefan Harbich
You might be better off setting up a VPN.
Why not access it from VRM and the remote console?
tailscale is a VPN like mechanism that can run on Venus OS. My TailscaleGX package allows configuration and control from the GX device's menu.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
78 People are following this question.
