nikolas avatar image
nikolas asked
MPPT 75/10 with lynx distributor
We are currently looking into buying a lynx distributor for our small van conversion. We already have a MPPT 75/10 installed which is directly connected to our leisure battery with an inline 15amp blade fuse. We have been looking at getting some kind of fused bus bar and liked the look of the lynx distributor but are unsure of how this would work with the solar charger as the lowest rated fuse for the lynx distributor seems to be 40amps. Are we stuck having to go for a standard bus bar to which we would move the 15amp fuse, or do we have to just keep our MPPT directly connected to our battery and just have a bus bar for everything else, or can we make it work with the distributor?
Thanks very much
MPPT Controllers
Alexandra avatar image
Alexandra answered ·
@Nikolas
The 75/10 has a blade fuse in it. So it is already fused. Connect it to the bus bar/distributor though if you can.
