the-nook avatar image
the-nook asked
Can I connect the battery balancer alarm to the VRM ?
I’ve just bought three battery balancers to connect to my 48v system.
Firstly, I see an alarm and reset, can this be monitored/turned off/ used to shut the system down remotely via the VRM, should a problem be detected?
Also, I see in the instructions, comments regarding balancer wire, should a battery or batteries become open circuit, at differing percentages. Is the academic, if you use the largest wire that fits in to the balancer?
Last question, I have 12 batteries in three strings, does it matter which string the three balancers are connected to?
Many thanks
Ian
leisure batteries
Michelle Konzack avatar image
Michelle Konzack answered ·
Plese read the bocklet "Wiring Unlimited"
If you have 3 Strings of Batteries, then you have two solutions:
1) Use on EVERY STRING 3 BatteryBalancer
or
2) Of cross connect the Batteries and use only 3 BatteryBalancer
Note: This is all written in the Documentation. (RTFM = Read The Fine Manual)
the-nook answered ·
Great, thank you.
I’m already cross balancing.
How about the other questions?
Thank you
the-nook answered ·
Would anyone mind pointing me in the right direction to somewhere that can answer my questions please?
Many thanks
derrick thomas avatar image
derrick thomas answered ·
In order to monitor the midpoint alarm on vrm, connect the alarm outputs to a digital input of the cerbo, then set alarm parameters for the digital input. When triggered, you will receive an alarm from vrm.
the-nook answered ·
Great, thanks.
I don’t have a cerbo.
Or is there one built in to the easysolar I have ?
Thanks
