vigilant avatar image
vigilant asked
Charger & Inverter Suggestion
I have a solar trailer that came with the following Victron equipment:
  • MPPT 150 | 70
  • Smart Shunt 500A
  • Smart BatteryProtect BP-65
  • Cerbo-S GX
  • GX Touch 50
It also came with the following non-Victron equipment that I would like to replace with Victron equipment for monitoring purposes:
  • Mean Well NST-450-1-24US sine wave inverter (Input: 20-33VDC, Output: 120VAC, Output Power: 450W continuous, 900W Surge)
  • YEWY UY-2500 Battery Charger (Input: 90-130VAC, Battery: Lead Acid, Voltage: 24V, Current: 65A)
The trailer has a 30A input plug where I can connect a shore line to grid power or a generator if necessary.
Also the trailer is equipped with 3 - 435W solar panels and (6) 200Ah AGM batteries.
The inverter will most likely not be used often. Just looking to replace the existing equipment with similar sized Victron equipment.
I was looking at the Victron 24/500 for the inverter but I'm stuck trying to find a comparable charger.
charger
kevgermany avatar image
kevgermany answered ·
The higher output centaur chargers are probably the closest match.
But you may be better off with an integrated inverter charger from the multiplus range.
snoobler avatar image snoobler commented ·
I'm not seeing any of the smaller 24V multis for 120V. Scads for 230VAC.
Smallest 24V multi in 120V is the compact at 2000VA.
I'd just stick with the Phoenix 24/500 and use the charger you have unless you need it integrated.
vigilant avatar image vigilant snoobler commented ·
I'd like to be able to monitor the incoming AC so that if it's disconnected I would get an alert. Is there an accessory that I could utilize for this?
Chargers.
