oli-clarke avatar image
oli-clarke asked
MPPT not getting into absorb, only bulk
bulk-then-drop.pngscreenshot-20240521-105312.pngI have a MPPT 75/15 connecting a 110Ah Leisure Plus battery and 160W panel.
All was working well, until the last week, whereby I seem to get a short period of bulk charge, which then cuts out and drops to charger off - where I would normally see abs/float.
Any ideas why this might be? I don't think I have changed any settings, the wiring appears ok.
MPPT Controllers
klim8skeptic avatar image
klim8skeptic answered ·
@Oli Clarke There is a firmware update available.
Download Victron Connect 6.10beta4 and apply mppt firmware v1.64.
4 comments
oli-clarke avatar image oli-clarke klim8skeptic ♦ commented ·
I don't seem to be able to get the APK to install - I'm on a Pixel 6, so the ARM format should work. I enabled allow unknown source, so strange.
Is there an alternative way to get the firmware onto the controller?
oli-clarke avatar image oli-clarke oli-clarke commented ·
never mind - had to uninstall the old app first. I've updated the app and firmware now. No immediate change, but will monitor and see what occurs
klim8skeptic avatar image klim8skeptic ♦ oli-clarke commented ·
