gordon avatar image
gordon asked
Orion XS 50 amp
Wiring in an F150 220 amp alternator to the rear bumper Andersen connector. Is there a difference between using 4AWG CCA wire and 4 AWG copper? Does it make a difference with solid vs twisted wire? Can I use only one wire by grounding the negative side andersen connector to the frame. I was thinking of using a battery jumper cables and spicing one wire half the length required.
Thanks
wiring
