mdk avatar image
mdk asked
High Voltage Alarms BSLBatt
whatsapp-image-2024-05-20-at-135557-4c109be3.jpgwhatsapp-image-2024-05-20-at-135611-068cd48d.jpgwhatsapp-image-2024-05-20-at-135628-e9f9515c.jpgwhatsapp-image-2024-05-20-at-135741-fd170e98.jpgHi everyone,
Lately I've been running into issues where Im getting a ton of High Voltage Alarms normally when the batteries are full or near full charge. System is around 3 years old.
My setup:
Venus GX (v2.92)
MultiPlus-II 48/5000/70-48 (v482)
SmartSolar MPPT VE.Can 150/100 rev2 (v3.13)
4x BSL Batt B-LFP48-125E - 48V (51.2V), 6.4kWh, 125Ah
I have no idea where to even start looking for the issue but I do have the home integration for my system so I do collect and store a lot of info. I've attached some of the screenshots from the recent alarms.
overvoltagebslbatt
mdk avatar image mdk commented ·
Just checking in if anyone has any ideas
nickdb avatar image
nickdb answered ·
Like all of these type of events, it is reported by the BMS.
So the standard advice applies.
Double check the settings vs the BSL reference setup doc
https://www.victronenergy.com/live/battery_compatibility:bsl
Use VRM advanced widgets to chart cell min/max from the BMS - this will show if there is a disparity.
If there is one, the GX should report which cell this is.
BSL have PBMS tools which allows you to connect to the battery and check the BMS readings as well.
@nickdb thanks for the response. I followed the guide you sent and these settings look correct now. Looks like they weren't adjusted after my last 2 batteries got added.
Not even an hour later same result. High voltage alarms
nickdb avatar image nickdb ♦♦ mdk commented ·
New batteries is an important piece of information that should have been mentioned.
New batteries will have these issues, it can be a pain adding to an existing pack. New batteries should be master. They should be charged to a similar level before being added.
BSL is slow to balance and the errors are normal on young batteries. Its best to leave them on keep charged for a few days.
Again, check the charts for min/max cell voltage.
I would chat to your supplier for help as this isn’t easy to diagnose over the internet without all the detail and suitable access.
Alexandra avatar image
Alexandra answered ·
@MDK
How much later were the batteries added?
There is usually a sticker on them somewhere with their firmware number on them.
They made quite a few firmware changes. Might need to see if you can get them (BSL) all onto the same firmware.
Victron & BSLBATT Lithium batteries
