Solar panels and 12V battery already hooked up. Can you hook up a terminal for charging a Grecell T-500 to load on the controller? Will it bi pass the 12v battery? Basically Solar panels direct through MPPT to charge G-Cell..Thank you
The load out-port is powered from the battery, not the PV, as described in the manual.
104 People are following this question.
