rvnomad avatar image
rvnomad asked
50 amp RV, MultiPlus II 2x120 and mini-PCS interactions
I have a 50-amp RV that came with a mini-PCS load control system. It's manufactured by Precision Circuits, Inc. I've attached a picture and the schematic of what it's supposed to do.
00-10024-000-Power-Control-System-Mini-System-Wiring-Winnebago-E.pdf
I have now installed a Victron MultiPlus II 2x120 3000VA unit in my RV and am passing through both 50-amp legs as follows:
Shore power & Onan 5500 generator -> Auto Transfer Switch -> Victron Inverter -> main distribution panel (monitored by mini-PCS).
Is there any benefit to keeping this mini-PCS load shedding system? I suspect it is not doing such a good job especially when the generator is running as it keeps turning off the AC even though there is enough power to run it. It may also be that my Onan 5500 generator needs to have the L2 -> L1 mod done to it to work better with the Victron.
All information and ideas are appreciated.
Multiplus-IIbalanced ac-load
