markwinship avatar image
markwinship asked
BMV-700 with Solar charger and 200Ah Lithium battery exhibiting strange behavior
In the morning, the BMV-700 indicates a SOC of say 70% with the 200Ah Lithium battery. When the sun comes up, solar charging starts. I have 3 * 120w solar panels charging through a REDARC BCDC1240D charger on a Lithium profile. The strange behavior is that by 8:30am the BMV-700 indicates a SOC of 100%. Now the amps deficit at 70% SOC is about 60ah; with sunrise at 6:30am and a maximum charge of about 20amps, how is that possible? The BMV-700 is all factory defaults except Charge Efficiency is set to 99% and the Peukert's exponent is set to 1.05.
BMV Battery MonitorLithium Battery
"a maximum charge of about 20amps, how is that possible?"
The Redarc 1240D is capable of 40a output.
Post a pic of the BMV settings.
John Dickfos avatar image
John Dickfos answered ·
I was having a similiar problem, and had not adjusted the tail current setting (03). Its set at 4% (of battery capacity) by default. The BMV manual on page 18 shows info for settings 01, 02, 03 & 04 that you may need to change from default settings for your installation.
markwinship avatar image markwinship commented ·
Thanks; this does make sense.
markwinship answered ·
Thanks; I realize that my REDARC 1240D is CAPABLE of 40a output, but this is without being attached to the car, so the only input is Solar. 3 X 120W panels = 360W or 360W / ~18V = ~20a, so how can the 60ah deficit be recovered so quickly when this is the maximum theoretical?
In addition, when this happens using solar power, even though SOC shows 100%, the BMV-700 shows positive 20a for quite some time before reducing to a couple of amps (presumably when float stage is reached).
