hi
If I have two Multiplus in parallel , for inverter N01 ( main on & inverter Light up alternately) for inverter N02 (main on & Bulk Light up with each other )
is this OK
hi
is this OK
There is a app that you can download to your phone search your app or play store and search victron, then select the toolkit app and install, this program will tell you what all the different combinations of lights mean
9 People are following this question.
