petercarnyx avatar image
petercarnyx asked
Solar History: Zero Yield when new batteries fitted
Hi, Unit is a SmartSolar MPPT 150V 35Amp. We have battery system set to 24VDC (2 x 12V 140AH Leisure Batteries). The batteries were connected before the solar panels. For the first 9 days the PV Yield was zero. So the batteries were discharging. Day 10, the Battery output maximum voltage dropped from 18VDC to 14VDC and it started to register a Yield. 4 days later the voltage went back over 14V and the Yield is back to zero.
Question: Is it likely that the charge controller thinks it is a 12 volt system?
thanks
smart solar charging behaviour
klim8skeptic avatar image
klim8skeptic answered ·
@PeterCarnyx Question: Is it likely that the charge controller thinks it is a 12 volt system?
Possibly. Check the mppt's settings to check that is has been set to 24v battery.
The firmware should have been updated and the system recommissioned.
This should include being programmed with the battery chemistry and correct charge voltages.
