Hi
I am trying to get the totals precast for consumption and yield on the vrm dashboard.
Can you advise me what parameter by installation and atributes have to be selected or which parameters are used to calculate them?
![solarvrm.jpg](/storage/attachments/78136-solarvrm.jpg)
Hi
Here are the parameters (see image) for todays forecast of solar (yield). result is in watt hours not in kWh. Play with other combinations (consumption forecast) or time parameters.
Hello
I can get the data as you have shown it, but I can't get it to match the values on the vrm portal.
I think it is easier to read the HTML page and extract the data than to start guessing games to get the data. It is a pity that I seem to be the only one who is not able to put the data together in such a way that it fits
You are right, data retrievel differs. This is already reported to the dev-team of the victron-vrm-api: https://github.com/dirkjanfaber/victron-vrm-api/issues/17 Hope they will find the reason soon and fix that problem. Feel free to use your own access to vrm, but it's like reinvent the wheel if other methods already exist.
39 People are following this question.
