egautherot avatar image
egautherot asked
which controller for two 175W 12V panels parallel or series
which controller should I select for two 175W 12V panels connected either in series or in parallel
MPPT Controllers
Duivert NL avatar image
Duivert NL answered ·
You will have to put them in series, otherwise a mppt will not start, voltage needs to be 5v higher then output
So in series they are 24V and about 14A so a small mppt is fine 100/20 for instance
Check your panels here and see what mppt is best
https://www.victronenergy.com/mppt-calculator
