Pontus Lindberg avatar image
Pontus Lindberg asked
AC Current sensor giving the wrong value
I have a 3-phase ESS-system with an AC-coupled PV-system.
I am using 3 AC current sensors ( https://www.victronenergy.com/meters-and-sensors/ac-current-sensor), connected to the temp-inputs on the Multiplus'es to show the values from the PV-system.
The problem is that my Victron system gives me way to high values.
In this very moment, my PV-inverter is producing 14200W, but according to Victron its about 21200W.
How can I calibrate this?
Multiplus-IIAC PV Coupling
Duivert NL avatar image
Duivert NL answered ·
There is the problem, manuals says 1,2,3 on for 7kw not 4 :)
Are they setup right? Dipswitches set right? Wired right?
There normally are not very accurate/slow but this is a bit to much
Pontus Lindberg avatar image Pontus Lindberg commented ·
I hope so. The dipswitches are all set to 7kW (no. 4 on, rest off) as my total solar is about 20kW.
Wiring should be correct aswell.
I havent really found any other settings for these, are there?
Pontus Lindberg answered ·
Yes! That was it. I missunderstood this image and had it set up the exact opposite :)
Duivert NL avatar image Duivert NL commented ·
Yes its a misleading image :), glad its solved!
