Hello, I have a MultiPlus 12/1600, and I would like to use it to power a 1450w coffee machine. However, when I power the coffee machine, an annoying overload alarm (display+cerbo gx) goes off. Why does this alarm go off? Can I disable this alarm?
What kind of coffee machine?
Some actually have a higher peak power that is pulsing, in average that's around 1450W but the peaks are higher.
The MultiPlus doesn't like that pulsing and your 1600VA MultiPlus only has 1300W of continuous power.
I need a compact machine, they are all 1450w. the load is resistive so it would be 1450va, lower than the 1600va of the multiplus
111 People are following this question.
