motees avatar image
motees asked
702 only?? Not 712??
The instructions I received with my 712 only shows instructions for the 702 and 700.
Are the instructions for my 712 the same as for the 702?
Also, the + positive wire from +B1 to the battery has a label on it that says "702 only". Is this wire also OK to use with the 712 also?
wiring
nebulight avatar image
nebulight answered ·
Yes. The 702 and the 712 are the same unit, but the 712 has built in bluetooth:
https://www.victronenergy.com/blog/2019/08/27/battery-monitors-and-monitoring-solutions/
Stephen Otto avatar image Stephen Otto commented ·
I wouldn't call them the "same." For example, the 712 is recommended for lithium batteries because it has a lower power draw.
