shane bourgeois avatar image
shane bourgeois asked
not working? VE.Direct library for Arduino
hello in the past ive set up 3 of units esp8266 with Victron Energy SmartSolar MPPT 100V 20 amp 48-Volt.
I have a new unit here tryingto pull information and i cant seam to get anything.
Anyone else have issues with the library or maybe its the newfirmware for the MTTP100/20?
arduino
4 comments
@shane bourgeois
Moved to modifications forum. More chance of an answer.
shane bourgeois avatar image shane bourgeois kevgermany ♦♦ commented ·
Thank you
Hi @shane bourgeois
Which library are you using? Do you have a link to the code? I am wondering whether the library is able to handle VE.Hex messages coming directly after the VE.Direct text frames.
Kind regards,
Thiemo van Engelen
shane bourgeois avatar image shane bourgeois Thiemo van Engelen (Victron Energy staff) ♦ commented ·
Im using the "VeDirectFrameHandler.h" from https://github.com/cterwilliger/VeDirectFrameHandler/tree/masterfor
for my test code i had been using https://community.victronenergy.com/questions/33570/smartsolar-settings-for-vedirect-rx-tx-communicati.html
I really like biozor code from Sep 07 2023 esp8266.ve.direct3.zip
Thank you for your help!
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @shane bourgeois
You need to make sure that the hexRxEvent function only returns true when inbyte == '\n':
bool VeDirectFrameHandler::hexRxEvent(uint8_t inbyte) {
  return inbyte == '\n'; // stubbed out for future
Otherwise there might be problem with hex messages that are transmitted immediately after a text frame.
Kind regards,
Thiemo van Engelen
shane bourgeois avatar image shane bourgeois commented ·
sadly no change in result
Thiemo van Engelen (Victron Energy staff) avatar image Thiemo van Engelen (Victron Energy staff) ♦ shane bourgeois commented ·
Hi @shane bourgeois,
Can you give a zip file with all the code?
And can you give a dump of all the raw byte values that the esp is receiving?
Kind regards,
Thiemo van Engelen
