App connects, did firmware update, but only goes to setting details nothing else
I assume that it shows the Product Info page, and that it only shows the Bluetooth interface and not the SmartSolar itself?
If this is not the case, can you please add some more information and perhaps a few screenshots?
If you indeed see the Product Info with only the Bluetooth interface, then this means that there is no communication between the internal bluetooth dongle and the MPPT part of the SmartSolar. What you can try is to power cycle the SmartSolar by disconnecting the PV and battery for 2 minutes and then reconnect them battery first. If this does not help, then there is a hardware problem with the SmartSolar.
Kind regards,
Thiemo van Engelen
39 People are following this question.
