76hokie avatar image
76hokie asked
BMV712 State of Charge always 100%
The display always reads 100% regardless of voltage. One particular instance the voltage: 12.83 volts, current: 15.3A, power: 196W, Consumed Ah: 0Ah, time: Infinite. I've rechecked the wiring and I am at a loss. I do not have Solar on my Travel Trailer. Any help would be appreciated.
BMV Battery Monitor
thomassolar avatar image
thomassolar answered ·
Jus a Guess since the measurement of current seems to be POSITIVE and not NEGATIVE:
Could yo by mistake have turned the shunt in the wrong direction? Connecting LOAD to the BATTERY terminal, and the BATTERY to the LOAD terminal...??
(Because when you use energy from the battery, Your BMV should show you a NEGATIVE current flow…)
