leon-vilsgaard avatar image
leon-vilsgaard asked
Battery charge rate only 90 %
In my boat I have an Centaur 12/20 to keep my two batteries fit and ready.
My battery for engine start is a normal lead acid (60ah), and my battery for consumption is a brand new AGM (95ah).
I have a battery monitor (NASA Clipper BM2) to monitor my AGM battery and it seems like it never get charged 100 %, more like 90-94%.
I know, that the charger has different jumper settings for the right kind of battery.
After talking to the dealer about my setup, I was advised to leave the jumpers in the lead/acid mode - is that the root to my problem?
Would it be better to set the jumpers for AGM, or wouldn’t that leave my startbattery with a too low charge voltage ??
Or is the only solution to by an AGM battery for engine start as well?
Thanks for advice
battery charging
Hi, there are two things to check: proper configuration & operation of the charger.
And two, configuration and operation of the monitor.
In case you had a victron battery monitor, I’d recommend to watch our youtube video on synchronization.
Hope that helps!
