I am connecting a 12/800 inverter to my alternator and in the begging it works fine. I will be using it for max of 500W and the fuse I use is 50 amp with a wire that is 8mm2 4 meters. However when I connect my 470W charger, it shuts off and give the low voltage error. I am measuring with a multimeter(on the screws at the top of the input) and it does not drop below 13V. Can someone tell me what I am doing wrong? Do I need bigger wires or is something else the problem?
