tobinp avatar image
tobinp asked
Communication Failure after v3.31 update
Ater installing the update (via auto update) communication via the vrm portal and victron connect app is in error. Unable to check for firmware updates with communication error.
Status: Connection established, retrieving list of devices..
Error
The site's two-way communication service did not respond. Have you enabled it on your GX device?
Note: It can take up to one minute after the firmware update for the device to come online again.
Error: 1392
This has only occurred since the update
As far as the victronconnect app: Connecting progresses to 40% then errors
1714427191346.jpegI believe there is a possible issue with the new firmware update
errorMQTT
Victron MQTT readme
