LoUpgraded to my 1st LiFePo4 battery after 9 years and 3 sets of Gel batteries.
System works perfectly except that occasionally the system restarts and connected loads lose power.
System is restored usually within a minute.
Manufacturer doesn't specify Absorption Voltage so I dont know where in VE Configure 3 to insert Absorption Voltage.
Manufacturer specified Bulk Voltage but I dont know where in VE Configure 3 to type in Bulk Charging voltage
Done some reading on the High DC ripple and my question is exactly what voltage settings do I need to configure in VE Configure 3 to prevent the batteries BMS from kicking the Inverter off occasionally?Logs from Inverter. Not all were logged but at least this incidence was logged
The new liFePo4 Battery
Alarm message I received from the VRM Portal
