Turcescu Vlad Nicolae avatar image
Turcescu Vlad Nicolae asked
Dynamic ESS doesn't respect the battery charge limit and the export limit
My name is Vlad Turcescu and I am writing this message because I saw that Dynamic ESS doesn' t respect the battery charge limit and the export limit. Test this function on your own system consisting of: MultiPlus II 10kVA, Fronius Primo 8.2 connected in the micro-grid and an MPPT 150/100. I also attach images with the settings and the moments when it doesn't respect the set limits.
Another problem is that when charging the battery, it provides its own consumption from the grid and not from the sun.
I mention that I am running the latest version of firmware v3.40-10
Thank you for understanding!
dynamic ess
