ripper avatar image
ripper asked
SSD relay to switch remote on Phoenix series
I want to have the solar charger connect and disconnect the inverter due to voltage.
Can I use SSD relays to switch the remote channel of Phoenix inverters? My concern is leakage voltage as they are usually non potential free.
Alternatively, they seem to be using battery voltage across the little bridge.Do I need to connect the two ports via a relay or is it enough to provide a "high" signal from the load controller?
inverter current draw
Hi @ripper
It's best to use a relay connected to the load output, and use that to switch the remote connection of the inverter.
