pfleu avatar image
pfleu asked
Van rig from one to two Orion DC to DC chargers...
orions-in-van.jpgHI all
I was wondering, since I already got one Orion 12/12-30 to rig in my van, what wire gauge should I pass from the van's battery to the Orion to be able to hook up a second Orion (probably the new 50A model) eventually. I don't want to re-do everything again in the future so passing an oversized wire seems ok ? Van batt 3 meters (10 feet) away from the Orion(s).
Would going from #1 to #2 be ok regarding all the wires gauges and connections ?
Thanks in advance for your knowledge !
Orion DC-DC Converters not smart
eljefe avatar image
eljefe answered ·
Equipment chassis ground of inverter should be no more than 1 gauge smaller than the +cable supplying the inverter. If you followed that rule, you may be able to put a larger cable to your dc-dc +bussbar. Use a dc circuit sizer to calculate your +feed to your dc-dc bussbar. I would attach a PDF of one of our CAD drawings of your exact situation but not sure the forumn allows.
Forum does allow. Depending on you having sufficient previous posts. Try, it will reject if it doesn't like it.
