hersjoen avatar image
hersjoen asked
DC ripple lithium lifepo4 48v
Hey, I'm struggling with DC ripple alerts. They're okay after 20 SEC. They occur when the sun is charging. It's a 16-cell lithium LiFePO4 with 48 volts.
Settings on the shunt are:
BC:140Ah
CV: 52,7V
DF:10%
TC:4%
Charge detection time: 2m
Peukert exponent: 1,05
Charge efficiency:99%
current threshold 0,10A
Time-to-go averaging periode: 3M
I've tried adjusting down the charged voltage, but it still happens. Should I continue to adjust it down or are there other settings that need adjusting? Or perhaps other things that should be checked out?
ripple
nickdb avatar image
nickdb answered ·
Ripple has many causes, from poor connections to a battery that can’t deliver the load it is being asked to carry. It isn’t something you could usually tune out of a system.
hersjoen avatar image hersjoen commented ·
The dc ripple warning only happens when the batteri is full. I suspect the battery BMS cutoff. So hopefully I can adjust that.
Alexandra avatar image
Alexandra answered ·
@Hersjoen
Probably also charging too fast. Assuming you have a GX as that is where you are usually warned about dc ripple. And an inverter since that is what measures DC ripple.
Use DVCC and tune the charge amps down, especially if it is happening near full with full charge amps.
Settings on the shunt are irrelevant if your mppts or inverter are nor programmed correctly.
Yes, i have a cerbo GX and a multipluss 2. The dc ripple warning only happens when the batteri is full. I suspect the battery BMS cutoff.
Should DVCC be on?
