afreedomvan avatar image
Can there be removable panels in an array?
I'd like to have (2) 100W solar panels on the roof of a van. Is there a simple solution to have (2) extra 100 W panels to plug in when parked? Would the charge controller just need to be sized for 400W? Is there any kind of simple disconnect system available to add the 200 W in series to the panels?
Solar Panelcharge controller compatibility
Kevin Windrem avatar image
For a series connection, you need to short out the connector you use to plug in the extra panels. This could be done by inserting a dummy plug with the pins shorted, but there's an easier way:
Connect a schottky diode between the pins of the connector or use MC4 Y cables and Diode mounted in an MC4 housing. The diode orientation needs to be such that the current from the roof mounted panels flows through the diode.
Share
Silas avatar image
Series not realy (somebody might make a connector to make this work), parallel sure trivially easy. I use a pair of MC4 connectors behind the skirting, just connect up the portables once I'm at camp. As long as it's within the specs of your MPPT should be fine.
Share
