tonka avatar image
tonka asked
Optimal charging current / why no adjustable max current?
Hi guys,
If an optimal charging current lies between 0,1 and 0,3c of rated Ah (*right?), why is there no charger with a variable current limiter?
*is the minimum charging current really 0,1c or can you go lower?
Cheers.
Tonka
battery chargingcurrent limit
tonka avatar image
tonka answered ·
Here it says you can quickcharge a leadacid battery, if you use a good charger:
https://www.powerstream.com/SLA-fast-charge.htm
Any thoughts?
Cheers
wkirby avatar image
wkirby answered ·
The maximum charging current is adjustable.
Here is a 30A rated MPPT controller.
The maximum charging current can be adjusted to whatever you like. Here I have adjusted to 1A
