darrenb avatar image
darrenb asked
Victron 75/15 max output / How to stop inverter draining battery.
Hi, I am wondering what the max output is of the controller as i can only seem to run a very small led light, anything else makes it cut off.
Also I just purchased an 1100w inverter which works great and is connected straight to the battery, but is there a way to stop it completely draining the battery, maybe something where i can change the voltage cut off like i can in the controller app?
Running 100w panel sometimes 2 depending on vehicle.
100ah lithium battery
Victron 75/15 bluetooth.
MPPT Controllers
Alexandra avatar image
Alexandra answered ·
@Darren.B
The 74/15 can output 15A.
Use the load output of the mppt to switch the on off switch for the inverter maybe? No idea what inverter you have.
darrenb avatar image darrenb commented ·
Ive got an energizer 1100w inverter. How would you do that? You cant connect an inverter directly to the mppt output!?
Alexandra avatar image Alexandra ♦ darrenb commented ·
Can you program the energiser?
How do you feel about product mods?
Isee it does have a remote option. Looks neat. Not sure how that works but possibly hackable.
The easiest way is to pop out the physical on/off switch and use the load output to drive a contactor that switches the 'switch' wiring based on desired mppt settings.
Mod can be reversed if you can do it nicely.
