diederik avatar image
diederik asked
Adding number
I'm struggling with a simple math function in my Node Red flow.
This doesn't work:
maxBattery = ((80-(100*(sum/1000)/15.4)).toFixed(2))+20;
msg.payload = maxBattery;
return msg;
This does:
maxBattery = 80-(100*(sum/1000)/15.4)).toFixed(2);
msg.payload = Number(maxBattery)+20;
return msg;
Why?
Node-RED
matt1309 avatar image
matt1309 answered ·
Hi @Diederik
Dynamic typing strikes again....
I'm pretty sure this is because javascript is treating first code snip you provided as a string so the + 20 is concatenating 20 as a string rather than evaluating the expression as you expect.
However you're telling JS maxBattery is of type Number in your second option so it's adding the number using addition not concatenation
This might make it easier to follow Assuming sum = 1000
Code snip 1:
maxBattery = ((80 - (100 * (1000 / 1000) / 15.4)).toFixed(2)) + 20
          = ((80 - (100 * 1 / 15.4)).toFixed(2)) + 20
          = ((80 - 6.493506493506493).toFixed(2)) + 20
          = ("73.51") + 20
          = "73.51" + "20"
          = "73.5120"
Code snip 2:
maxBattery = ((80 - (100 * (1000 / 1000) / 15.4) + 20).toFixed(2))
          = ((80 - (100 * 1 / 15.4) + 20).toFixed(2))
          = ((80 - 6.493506493506493 + 20).toFixed(2))
          = ((93.5064935064935 + 20).toFixed(2))
          = (113.5064935064935.toFixed(2))
          = "113.51"
diederik avatar image diederik commented ·
Code snip 2 was the way to do it. Thanks.
diederik answered ·
Hi @matt1309,
Dynamic Typing :-)
I'm getting an array from the Solar Yield Forecast.
This is the complete function. Where do I start using strings?
var acThreshold = 400;
var sum = 0;
var toAdd = 0;
for (let i = 24; i < 48; i++) {
    if (msg.payload.records.solar_yield_forecast[i][1] > acThreshold){
        toAdd = msg.payload.records.solar_yield_forecast[i][1]-acThreshold;
    else{
        toAdd = 0;
sum += toAdd;
//maxBattery = ((80-(100*(sum/1000)/15.4)).toFixed(2))+20;
maxBattery = (80-(100*(sum/1000)/15.4)).toFixed(2);
return msg;
matt1309 avatar image matt1309 commented ·
Hi @Diederik.
I believe it's literally the line you mention.
The toFixed(2)
method returns a string representation of the number with a fixed number of decimal places.
