d4h-ottmar avatar image
d4h-ottmar asked
(Obsolete, changed to github) Node-Red Node = Victron-vrm-api Q&A (especially @ Dirk-Jan Faber)
Hi Dirk-Jan, hi Guys,
i want to discuss some possible bugs and extensions of the node Victron-vrm-api. First, is this the right place/platform, or does it make sense to use Github?
Generally it works, but i detected some weird data und limitations to parameterize.
Let me know
Thanks Ottmar
Node-REDapi
4 comments
@d4h Ottmar
Post in the node red dedicated space here.
https://community.victronenergy.com/smart-spaces/71/node-red.html
Git hub also would be a good space
d4h-ottmar avatar image d4h-ottmar Alexandra ♦ commented ·
Thanks Alexandra,
this was my goal starting the post, but i haven't found a way to achieve this directly. Can you give me a hint?
Is it moved already?
d4h-ottmar avatar image d4h-ottmar Dirk-Jan Faber (Victron Energy) ♦♦ commented ·
okay, will use it further and mark this post as obsolete
d4h-ottmar answered ·
Okay, even to have no response so far, i will try to start with my questions:
Using attribute="installations stats", attribute="Solar direct use" and Interval="years" the start field can be defined to "- 1 week" only.
This delivers the total of one week not the total of a year.
Same behavior with e.g.attribute="Solar to battery"
Any ideas?
Maybe i'am way to early because node version is v. 0.2.1
