eleusis avatar image
eleusis asked
450/100 max charge current query
Im a little confused here of what the 100 stands for in 450/100. I know its amps but. .
From datasheet:
Max. DC output charging power 4000 W per tracker 5760 W total .
that more like approx 80 amps per mppt charging. So total approx 160amps total.
Yet the 100amp rated charge current is far lower 160a which the above seems to suggest. Which is it?
What is the max charge current that can go into a battery, assuming each mppt is maxed out?
MPPT Controllers
nickdb avatar image
nickdb answered ·
100A. Trackers can be imbalanced but the total cannot exceed 100A, it will be throttled to that.
