I need the file for v1.39 firmware for my BlueSolar 150/70 Charge controller. Please who can help with it? (I usually connect to my controller via the VE.direct-USB cable).
Use VictronConnect, it will update to v1.39.
The other source is https://professional.victronenergy.com.
It has change log and latest files. Which in this case is already v1.42/v1.43. VictronConnect will soon be updated to those same versions.
Hi @mvader (Victron Energy Staff),
I have initially upgraded this BlueSolar mppt to v1.42 (through the self supplied firmware upgrade method), as it was initially on v1.30. But now I wan to downgrade it back to v1.39 pending when v1.42 is not on VictronConnect.
Hi Henry, sorry, but thats not possible, see the changelog. You can’t downgrade.
I don’t see why you’d want to downgrade; its not necessary.
Thanks for your feedback. I narrowed down the issue of a poor PV voltage to a tripped DC breaker. I initially though it could be the firmware versions.
Thanks once again.
Hi Henry, ok! Great to hear that its resolved; thank you for letting me know.
12 People are following this question.
