Michelle Konzack avatar image
Michelle Konzack asked
Controll a VE.Direct device or similar from VenusOS?
Good day,
currently I develop a new device for my farm using an ESP32 module which is using the VE.Direct protocol and like to know, if someone has a code how to send data from the VenusOS over VE.Direkt to the device.
I want to stream the data ("Maximum Power allowed" and "current Output Power") as streaming TXT data over the VE.Direct bus and receive data to set the "currentOutput Power" maybe a HEX. (it would be the same as for the SmartSolar/BlueSolar)
Note: It is something similar to the Fronius Ohmpilot but in DC version.
With this, I have not more to relay on an a fixed Power Output (if battery become full and I have not enough consumer running), but can regulate a resistive load up to 100A by PWM based on the Data from VenusOS and the MPPTs , SmartShunts (as EnergyMeter for Windmills/Hydrogenerator).
Thanks in advance and a nice day
Michelle
P.S.: My second project is a "SmartHydro MPPT 250/100-Tr VE.Can" and no, no Windmill support because the MPPTs already exist (WindMax from Schams Solar/Elektronik).
VE.Directcodeexternal device
VE.Direct protocol FAQ
