It allways shows 100%. The program most be wrong!
It's more likely a setup issue. Often whe this happens it's because the shunt is either the wrong way around or it has been bypassed and thus measures no current.
Would it be possible for you to detail your wiring. If you could post some pictures, that would be even better.
10 People are following this question.
Smartsolar mppt #119 settings data lost after loading settingsfile
Integrating 123\SmartBMS with Victron components like the Multiplus and Smartsolar mppt?
Firmware Update SmartSolar without Internet connection?
How many smart charge controllers can I connect to one colour control gx
Help with setting - 180w panel, MPPT 75/15 and 2 x 60ah gel batteries
